Clonking sounds
Compression and deterioration of the large foam rubber "donut" spring isolator bushings, Part 5, is a common cause of loss of ride height.
Cheers,
Don
These could also be another source of a soft thud. If you aren’t familiar with these, these are the muffler mounts located above the differential. You’d have to get under the rear of the car and move up and down the exhaust to see if there’s excessive play from those bushings.
TopHatChef
Nov 2, 2016 02:52 PM
