Code P0010 P0332
Old Jul 8, 2014 | 07:10 AM
blackhonor9's Avatar
Default Code P0010 P0332
I have been having issues with my 2000 Jaguar Vanden Plas. The first issue was the VVT Solenoids. Now, I am getting code P0332, P0010, P1384 and P1642. I think the P0010 and P0332 was because I had the VVT solenoids disconnected. Is this a correct assumption. I recently uploaded a video of the ticking sound my car is making. Please take a look. I'm also getting ASC not Available and Trac not available on display.
Old Jul 8, 2014 | 08:39 AM
JimmyL's Avatar
Default Codes
Well, if some codes were due to the VVT solenoids being disconnected, can you reset the codes and see what comes back ? With the TRAC and ASC messages, does the ABS light come on ? If it does, does it come on as soon as the diagnostic checks are over ? If so, you probably have the solder problem with the ABS unit. I fixed mine recently (ABS). It wasn't too bad to do, just a little tricky getting the unit out.
Old Jul 8, 2014 | 10:48 AM
Yes, the abs light is from start up. I will check the ABS unit. Thanks.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
