Coding Modules x308
Old Nov 9, 2014 | 04:18 PM
alfamaniacs's Avatar
Default Coding Modules x308
Hi Guys,
I have been looking at VCM IDS SSD software for the x308 - in all cases it says it cannot be used to recode modules - can anybody confirm this?
I will be needing it when I a fitting a new ABS module to my 2001 XJR
I am almost 100% certain that this module is going to have to be introduced to the CANBUS Controller as a new part.
Is the Auto Enginuity able to calibrate or code the ABS module?
Have any of you had any experience in this regard?
Andrew
PS Check this link:
Jaguar Land Rover Diagnostics Coding Programming Kit Dealer Software IDS SDD JLR | eBay
Old Nov 9, 2014 | 08:32 PM
sparkenzap's Avatar
The abs module does not need to be married to the bus.
Old Nov 9, 2014 | 09:18 PM
motorcarman's Avatar
The ABS module will need to be configured to the CAN bus IF it is a NEW module from Jaguar or it is OLD and has lost it's original configuration.
I have modules that I repaired and stored for around 10 years. When I install one it usually needs configuration as a NEW module. (capacitor discharge?????)
If a module has been removed from a running vehicle recently, then it should just 'plug & play'.
bob gauff
Old Nov 10, 2014 | 02:49 AM
Thanks guys ..... Bob, does auto enginuity have the capability to configure the abs module?
Thanks again
Old Nov 11, 2014 | 07:58 AM
I don't know anything about AutoEnginuity, I have only used WDS and IDS.
There are many diagnostic units that can be used but I don't know the specifics.
bob gauff
Old Nov 11, 2014 | 08:22 AM
RJ237's Avatar
There is no mention of configuring modules in the Auto Enginuity user guide.
Steviedee1st
Nov 28, 2023 06:32 PM
Forcedair1
Feb 19, 2020 01:51 PM
xjrjag
Aug 17, 2019 03:45 AM
vsol
Aug 29, 2018 09:46 PM
skyryder
Mar 25, 2016 08:18 PM
