Coil Boots
Old Oct 18, 2010 | 10:13 PM
TN8Shooter's Avatar
Default Coil Boots
I've recently replaced my spark plugs, and I noticed that the boots kind of sit on top of the plug. Are they supposed to fit snug on the tip of the plug?
Old Oct 19, 2010 | 03:52 AM
ABoxley's Avatar
Default just my 2p (~3.5c)'s worth
In my experience (put on and taken my boots off many times chasing a misfire) they were a pretty snug fit, producing a bottle cork like pop when removed.
Hence, if they are a sloppy fit I'd consider either looking for some 2nd hand replacements from a breaker (I got a full set of coils for the equivalent of ~$80 in good nick of a low mile car [worth remembering XJ & XK use the same parts so doubles your chances]) or apply some dielectric grease to either the plugs or inside of the boots to get a good tight fit.
I'm pretty sure they are supposed to be a good fit to keep moisture out of the system and stop them arcing to the block.
Hope this helps
Alex
SD96XJ6L
Dec 27, 2025 09:58 PM
Finbarr1975
Sep 5, 2025 08:38 PM
tlynch
Dec 31, 2020 01:58 PM
Bcrary3
Sep 27, 2015 12:21 PM
