Coil Cover Bolts
Old Dec 29, 2015 | 03:54 PM
soprecious's Avatar
Default Coil Cover Bolts
Help! Can anyone please tell me the size of the coil cover bolts (total of 6 holes per side) for an 1998 XJ8? Thank you in advance.
Old Dec 29, 2015 | 05:38 PM
avern1's Avatar
Its nice to meet another Jag owner from Omaha.
I removed one of mine and measured it. It is 4.87mm diameter X 12mm length.
I believe they would call that an M5 x 12. if not an M4 x 12 if you are not going to buy them at Jag for about $5.00 each I would recommend adding a flat washer since the OEM is a flange/shoulder type bolt.
Send me a PM and I will introduce you to a few of the other Jag owners in Omaha.
Old Dec 29, 2015 | 07:10 PM
RJ237's Avatar
Almost but no cigar. You need the thread pitch also, in this case M5X0.8 12mm
Old Dec 29, 2015 | 07:20 PM
BobRoy's Avatar
I have extra ones. How many do you need.
Old Dec 29, 2015 | 07:50 PM
avern1's Avatar
My oops forgot to measure the thread pitch. A bit chilly in the garage tonight.
Old Jan 2, 2016 | 11:15 PM
Bcrary3's Avatar
I posted it on here a while ago... I can dig up the thread about it..
I bought all my bolts from Fastenal (88 bolts in total) for about $22.00.
They can match the bolts used on the coil cover exactly. They have a few different options, I opted for the oiled flange bolts, I would also suggest class 10.9 (american grade 8). I will find it and post it for you.
__________________________________________________ __________________________________________________ ___
EDIT:
https://www.fastenal.com/products/details/11127077
those are the correct bolts. They are also the same for the coil packs as well as the covers.
The only difference is instead of being a 7mm head like the factory ones, these are a slightly more common 8mm head.
Old Jan 4, 2016 | 10:31 AM
soprecious's Avatar
We need all 12 as car was purchased without covers. What is your charge for mailing, etc? Thank you so very much.
Old Jan 4, 2016 | 10:32 AM
soprecious's Avatar
EDIT:
Thank you so very much for this info!
Acebars
53
Sep 19, 2016 04:11 PM
BobRoy
Jan 21, 2016 04:14 PM
seawind
Jan 5, 2016 10:35 PM
nebelfuerst
Jan 3, 2016 11:42 AM
fox5mx101
Dec 25, 2015 06:34 AM
