condensation
Old May 14, 2013 | 06:30 PM
davedella's Avatar
Default condensation
hello again
i have 2 questions
1-i hadto change my H7 headlamp on my 04 XJ8-ok fine it works -so i changed all 4 to a higher watt bulb-still fine-BUT now the passanger side has all condensation-i got a hanger with paper towels and wiped it all dry-guess what -its back the same day-i have the covers on right-although the bottom clip did fall off on the bottom -but it sits perfect in the way it should be-i put that little silica stuff (that comes in shoe boxes) for a day and nothing --HELP
now 2
2 i dont know but i feel the ride is i bit more harder the past few days-could i of knocked a wire off near the drivers side when changing light-cause i know the pump and something else with the air suspension is right under there-now once is a while i use to hear (now remember not all the time) like an escaping air sound when i use to hit the open door button on the remote-not often--i havent heard it in 2 days-now i did replace the driver side shock less than a year ago -so i paid attention to the ride and its the same left and right when a bump is hit -or am i way off target-is there something i could do to check this -no lights-no messages -car (in my head ) might look like its a bit higher -but i think its in my head HELP again
thanks
dave
Old May 14, 2013 | 08:23 PM
RJ237's Avatar
You are almost in the right forum, but not quite. You need to repost on the X350 forum, or maybe one of our kind moderators will move your post.
1100me
Aug 27, 2020 11:37 PM
swetnK
Sep 23, 2015 10:49 AM
Na5h
Sep 11, 2015 07:26 AM
johanasu
Sep 3, 2015 12:39 PM
