Coolant leak
Old Apr 30, 2019 | 09:44 AM
SWGOH CLONE's Avatar
Default Coolant leak
I am leaking coolant in my 01 V8 Vanden Plas from somewhere that appears to be above the transmission. It's a madhouse of hoses in the general area of where I believe the leak is coming from so I can't get a good view without taking stuff apart. I would like to avoid any unnecessary labor so any advice would be appreciated.
Old Apr 30, 2019 | 10:24 AM
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Apr 30, 2019 | 11:30 AM
avern1's Avatar
In the area you are describing there are at least a few major areas of concern. The first step is to have the system pressure tested. It will allow you to find the leak without the engine running. The heater feed and return hoses are in that area. The dreaded Norma coupling is there, the octupus hose is there and there is a small rubber elbow on the bottom of the throttle body. A static pressure test is the best way to sort it out.
You don't have a location in your info but I can recommend the Harbor Freight pressure tester has the necessary adapter for the Jaguar if there is one in your area. If not take it to a competent radiator repair facility and have them do the pressure test. Once you identify the location of the leak we can better advise you.
Old Apr 30, 2019 | 06:03 PM
Default Thank you for the info. I do have a harbor freight near me
I
Old May 4, 2019 | 10:39 AM
Len Apcar's Avatar
I agree with avern1, but while we on this, I lose about a cup of fluid every few months. There is no sign of moisture on my garage floor. Pressure test turns up nothing.
Is a loss like this normal?
Also, how much do you fill the coolant reservoir? I usually leave it a few inches shy of the top. Correct?
Thanks.
hen555
Jan 4, 2025 08:30 AM
Harry Peter Rose
Feb 13, 2018 08:14 PM
Z07Brandon
Jun 22, 2017 11:48 PM
Nee_the_Bogeyman
May 8, 2016 07:25 AM
chtp66
May 26, 2014 06:45 AM
