Coolant leak
Old Mar 3, 2022 | 01:02 PM
pcolapacker's Avatar
Default Coolant leak
Anyone ever have an intermittent coolant leak? Some days a small puddle under the front of the engine (drips off the sway bar) and some days nothing. Low level light comes on and I add to expansion tank every 7-10 days. Looks like thermostat tower and cross-over tubes dry. Looks like wetness under water pump pulley. Picked up some flourescent dye to add to make sure of location and ordered new water pump.
Old Mar 4, 2022 | 12:15 AM
Jeroen's Avatar
Yes, those pumps can behave very oddly. Mine did similar things, the odd leaking. Pressure tested the system and it held its pressure beautifully.
But I was glad to decide to replace the pump. It was very apparent it was definitely on its way out once I had it out. You might as well replace the thermostat as well.
Jeroen
Old Mar 4, 2022 | 06:49 AM
Thanks Jereon. Thermostat replaced when fixed leaky thermostat tower not long ago.
rf69
28
Jan 29, 2021 05:33 AM
pdfisherman
Dec 27, 2014 11:05 PM
L80ous
Jul 13, 2014 01:25 PM
jsulliva
May 30, 2014 11:12 AM
SteveSheldon
Apr 20, 2013 04:53 AM
