coolant level sensor leak, 2001 xj8
Old Oct 14, 2011 | 02:17 AM
cromero's Avatar
Default coolant level sensor leak, 2001 xj8
i just replaced my level coolant level sensor with one i removed from a donor from pull a part. it works fine but now i have a leak at the level senor. i knew it was just too easy. all i did was pull the old old one and then snapped the replacment one in. was i supposed to install an oring or other seal that i didn't know of?
thanks
Old Oct 14, 2011 | 03:54 AM
test point's Avatar
The tube that the sensor is installed into is an integral part of the tank. The tank should not leak even without a sensor in place. Old plastic is subject to cracking especially when motivated by the hot/cold, pressure/vacuum applied to the coolant tank.
Old Oct 14, 2011 | 06:43 AM
jimlombardi's Avatar
Hi
You might be able to buy a new cooling expansion tank for $177 (Gaudin Jaguar parts online) if it is available - they show a list price of $218. Part number is MNC4400AC. Ebay has used ones in the $190 to $250 range.
Jim Lombardi
Old Oct 14, 2011 | 06:53 PM
cromero's Avatar
good info guys, thanks
toronadomike
Jan 22, 2026 10:13 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
