Cooling fan noise
Old Apr 9, 2020 | 01:03 PM
Henkez's Avatar
Default Cooling fan noise
The cooling fan on my Xjr has become very loud. Have never heard it so loud before. What can be the cause of this ?
Old Apr 9, 2020 | 02:30 PM
Highhorse's Avatar
Have you checked your mounting points...to include the fan motor itself? A grommet may have eroded away?
Old Apr 9, 2020 | 09:21 PM
M. Stojanovic's Avatar
Just to eliminate the possibility that what you are hearing is the normal sound of the radiator fans (2 of them) when they are at High Speed. Up to certain engine temperature, the fans run at Low Speed (rather quiet) and are switched to High Speed (fairly noisy) if the engine temp goes higher. This is controlled by a special (long) fan relay located low down at the front LH corner of the engine compartment.
When a cold engine is started (AC off), the fans should initially not run at all. When the engine reaches 90C, the fans are switched on to Low Speed. At 97.5C, they are switched to High Speed. Do a test with starting the engine from cold (AC off) and let us know how the fans operate.
Spikepaga
Apr 6, 2015 08:49 AM
randyb
Feb 3, 2015 03:21 AM
vincent661983
Jul 8, 2014 06:10 AM
James Lewis
27
Aug 22, 2013 06:06 PM
