Cracks on Primary chain guides
Old Nov 6, 2018 | 06:35 PM
Jagman85's Avatar
Default Cracks on Primary chain guides
Hello everyone,
I've just pulled the cam covers off today to inspect the timing chain system & have discovered the following:
- Primary chain guides are cracked & therefore need replacing
- Secondaries are perfect & look as though theyve been done already with upgraded ones.
Ive checked out all the how-to's i can find so far & they all involve complete replacement. So my question is, am I able to replace JUST the primary guides & tensioners without all the other work involving locking the cams, removing the chains, removing the VVT components, etc? (So in other words, simply take timing cover off, replace primary guides & tensioners, put timing cover back on)
From what I can tell it can be done, but thought I'd get another opinion.
Old Nov 6, 2018 | 07:39 PM
M. Stojanovic's Avatar
Yes, it is fairly simple. See attached extract from the Workshop Manual.
Old Nov 6, 2018 | 07:54 PM
Carnival Kid's Avatar
I find it hard to believe that someone replaced the secondary (lower) tensioners, and not the primary (upper) tensioners. But if you already have the timing cover off, I would replace both secondary and primary tensioners, and all 4 chains regardless.
Old Nov 6, 2018 | 08:12 PM
Jagman85's Avatar
Maybe ive misinterpreted the definitions of primary & secondary. The ones for the exhaust cam have been done with upgraded ones & appear to be in perfect condition. But the guides for the chains driven off the crankshaft appear cracked. And out of curiousity, why would the chains themselves need replacing?
I would otherwise agree with replacing all components, but the cam locking tools are absurdly expensive to buy, so if I can avoid the need for them by only doing the forementioned then I will.
Old Nov 6, 2018 | 09:25 PM
Not really: https://www.ebay.com/itm/Jaguar-Land...kAAOSw~jpZvAui
Old Nov 6, 2018 | 11:13 PM
NBCat's Avatar
Replace the primary timing chains, guides and tensioners as the guides break and fall into the sump.
Use the proper tools and procedures as outlined here:
http://jagrepair.com/images/AutoRepa...Code%20168.pdf
Note page 74 regarding the proper camshaft timing.
sshowell99
Dec 19, 2013 12:49 PM
mbs xk8
Oct 23, 2013 03:49 AM
prelude4ws
Oct 3, 2010 03:13 PM
wmterry89
Aug 20, 2010 04:47 PM
