Crankshaft Seal Question
Old Jun 29, 2019 | 12:19 AM
OUScooby's Avatar
Originally Posted by nilanium
All X308's will have them. They keyed version was for older engines.
Is the bore of your crankshaft damper straight through, or is it tapered with the wide end towards where the bolt goes in? If it's straight through, it's most likely just so tight in there that you can't see the slot on it. If it's tapered, then the collet piece was lost somewhere along the way.
I'd knock the collet out if it's in there before reinstall, just to make sure everything goes together properly. New bolt too. Trust me, you don't want to roast your crankshaft from the pulley coming loose and spinning along... I did some damage to mine, but replaced everything (pulley, collet, bolt), built a crankshaft damper holding tool, and cranked the hell out of it, and it hasn't moved since. Some pictures of the damage from coming loose on a highway pull (and the correct seal orientation)
Here is a before pic of my pulley before I sent it out to be refurbished. I know you can't se much here. I'll try and take a pic of the refurbished one this weekend.
Old Jul 1, 2019 | 05:27 PM
OUScooby's Avatar
So here is my refurbished pulley, and yes I can see it in the picture. So that brings me back to my previous question, if all x308s have these then this cannot be the locking ring since the x308 workshop manual list models without locking ring. So what is the locking ring how do I know if I have it and which torque spec do I use?
Old Jul 1, 2019 | 05:33 PM
nilanium's Avatar
The big one. If I remember right the torque spec for keyed engines was around 80nm and for the collet-style was in the mid 200's (maybe they call it the locking ring in the fsm), don't remember the exact value, but it was a lot. Use that high one.
Old Jul 1, 2019 | 05:48 PM
Carnival Kid's Avatar
The collet is the "locking ring" you refer to. It is split tapered cone, allowing it to grip the pulley and the crankshaft when tightened. The torque setting for this is a whopping 375NM or 276ftlbs.
Here is a page from the X308 workshop manual.
Old Jul 1, 2019 | 05:57 PM
PORNO's Avatar
Told you it was stuck. You had me doubting myself even after doing 3 different Xjr’s haha. Anyways don’t work yourself up over that locking ring. That cone has several different names that Jaguar refers to it as. Split collet, split cone, locking cone, and a few others. You have the collet and the picture you provided proves that you definitely do not have the other. And as far as torque spec, it is 364-386 nanometers. IIRC the MY closer to 2003 have the collet and not the woodruff key.
Old Jul 1, 2019 | 06:08 PM
PORNO's Avatar
Forgot to answer a part of your question.
The split cone is the locking ring. No, not all x308’s have the locking ring/split collet. If you run into an x308 that does not have it, then that tells you that it is using the woodruff key in which case yours doesn’t have, albeit your xjr is MY 2000 correct?
Just for added confirmation, here are more instructions for removal and installation. The collet is referred to as a "split locking ring" in the removal page.
Old Jul 7, 2019 | 03:06 PM
  #28
OUScooby's Avatar
OK I'm convinced now, I'll use the 300 something NM torque spec. Going to kinda have to go on feel for that one, I think my largest torque bar only goes up to 250ft lbs.
Yes its a 2000MY
Old Jul 7, 2019 | 03:45 PM
I did the same, my torque wrench only goes up to 250ftlb, I torqued it to the 250 max and that is one hell of a torque, and it has been no problem since. A new bolt comes coated with blue loctite so there is a double security.
Old Jul 7, 2019 | 04:31 PM
  #30
OUScooby's Avatar
Yeah my plan is to torque it to the 250 ft lbs then use a breaker bar to try and give it and extra 1/8 turn for good measure.
Old Jul 8, 2019 | 10:29 PM
  #31
OUScooby's Avatar
Well I torqued it down to 250ftlbs the max for my torque bar. Then tried to turn it some more with the breaker bar but just couldn't get it to move any further. My breaker bar was starting to flex a lot to the point I thought it might break, and I was holding the crank pulley with a pair of those chainlink vice grips and a cheater bar slide over the handle. Ended up bending the chain grips so much to the point they are unusable now. So 250 ftlbs will have to do I guess.
Old Jul 9, 2019 | 07:04 AM
  #32
I'm sure it will be fine, 250ftlbs is a lot of torque!
Old Jan 9, 2024 | 01:48 PM
  #33
Vinman's Avatar
Default Crank shaft main gasket
There is no red seal on my 1998 jaguar xj8 crank seal replacement do they make the seals without them?
Old Jan 9, 2024 | 03:15 PM
  #34
Addicted2boost's Avatar
If you’re inquiring about the crankshaft front main oil seal, it’s not typically red in color. Every X308 car has a crankshaft front main oil seal. There’s also a very thin o ring on the backside of the harmonic balancer that also needs replaced.
Old Jan 9, 2024 | 04:09 PM
  #35
Vinman's Avatar
Yes I am asking about the crankshaft main oil seal. They keep talking about removing a plastic piece after installation. My seal does not have one is that normal? The seal is black and mine has a somewhat hard copper in color hard piece attached to the rubber seal on the inside. Oh by the way there is also a felt ring on the outside (facing out).
Old Jan 9, 2024 | 09:06 PM
  #36
If that inside hard copper piece looks removable, take it off. What brand is it?
Maybe take a picture of it.
Old Jan 9, 2024 | 09:26 PM
  #37
xalty's Avatar
stock is a ptfe seal. you take the red piece out when you're ready to go
OnFire
Feb 18, 2022 11:53 AM
Thorsen
Jul 10, 2021 03:03 PM
John Baker
Jun 3, 2020 05:00 PM
OUScooby
Apr 19, 2019 11:02 PM
Roadhogg
Nov 12, 2012 11:36 PM
