Cruise control..I know, I know
Old Mar 15, 2020 | 06:54 PM
3timejag's Avatar
Default Cruise control..I know, I know
I have seen other threads on this subject, but I can never seem to find an old thread when I need one☹️
I have a 98 XJ8 Vanden Plas and the cruise control is doing the “wngine failsafe mode” thing about 15 seconds after I engage it.
I replaced the brake switch, and no improvement. I remember seeing a thread on a vacuum tube? Location where under hood, and any other suggestions?
Have hard reset already.
many thanks!
Old Mar 15, 2020 | 09:23 PM
Highhorse's Avatar
One thing to check is pg 28 of this TSB.... http://www.jagrepair.com/images/TSB/...Flowcharts.pdf
Not sure if this will help, but give it a go... https://www.autoreservejaguar.com/ja...-actuator.html
Old Mar 15, 2020 | 09:55 PM
Addicted2boost's Avatar
There’s 2 vacuum tanks under the air filter base that has a plastic tube going to it from the throttle body and 3 VSV’s located under the black lid on the drivers side of the engine bay. Check this make sure it’s all hooked up first.
Old Mar 19, 2020 | 09:46 PM
3timejag's Avatar
I finally had a chance today to look under that black box on the drivers side. Bingo. There was a vacuum tube that wasn’t hooked up. All god, thanks to your direction. Many thanks sir!
Old Mar 27, 2020 | 04:27 PM
euphonium01's Avatar
Hi 3timejag, not sure if this can help, but I fittyed Cruise Control to a XJ8 Sport, and it worked perfectyly..
Sorry.. dodgy keyboard lol
Old Mar 27, 2020 | 04:38 PM
3timejag's Avatar
This is exactly what I needed, someone else explained it to me and I have since repaired it! This is a great reference picture though, first one I’ve seen. Going to save it and maybe I can help someone out at some point too. Many thanks man
Old Mar 27, 2020 | 04:39 PM
3timejag's Avatar
Old Mar 27, 2020 | 04:44 PM
Glad it helped and you can make use of it, took me an age to draw that in Word... lol
Paul
Old Mar 27, 2020 | 04:48 PM
3timejag's Avatar
😂👍 great job!
lynnpt2001
Dec 14, 2016 04:23 PM
xk8newbie
Oct 10, 2016 05:09 AM
Johnken
Sep 22, 2015 03:53 PM
smagl
Sep 3, 2008 09:45 PM
