Cylinder Coil Numbering and Letter Designations
Old Apr 8, 2017 | 07:44 AM
robertjag's Avatar
Default Cylinder Coil Numbering and Letter Designations
Greetings,
I need a little clarification. I am getting a bad coil reading (P0355 Ignition Coil "E" Primary/Secondary Circuit) on my 2002 XJ8 (manufacture date 8/2001).
I have found this sheet but I would like clarification that the middle numbering schematic is what applies to my vehicle. It seems obvious but it never hurts to confirm.
Thanks for the help.
Old Apr 8, 2017 | 09:10 AM
Addicted2boost's Avatar
The middle diagram for your engine.
Old Apr 8, 2017 | 10:02 AM
Don B's Avatar
Hi Robert,
It could be that the coil has failed, or it could be a problem with its electrical circuit. See the possible causes listed in the DTC Summaries Guide, which you can download at this link:
Jaguar X308 DTC Summaries Guide 2001
Cheers,
Don
