Diagnostic tool or software VCI sdd
Old Nov 15, 2021 | 01:47 PM
jean HJ's Avatar
Default Diagnostic tool or software VCI sdd
Hello
I know that there are some thread regarding diag tools.But it's still confusing which tool operates correctly with the right failure codes and may more information behond.i would use the tool mainly X308 350 358 serie. I've read noow as well that the mongoose software didn't work well on X308 so what would be a good compromise vci153 plus a may a gendan tool for the X308 many thanks for any advise / tips
Jean
Old Nov 20, 2021 | 01:12 PM
hispeed42's Avatar
I use an Autel MX808. It reads all of the modules.
Old Nov 20, 2021 | 09:01 PM
60Gunner's Avatar
I recently bought the CRP 123 Premium by Launch off the Snap On truck that comes weekly to the worlds largest Yamaha Golf Car Dealer I recently started wrenching for after 15 years as a truck driver. I picked it up for $50 used.
It's an entry level professional grade diagnostic tool with an amateur price tag and can be bought new for not much more than a $120 from I've seen online.
I've used it on my '03 XJ8 Sport and so far it works as intended. Quite happy with the purchase and it has really good reviews from what I've seen .
I was able to take it home for a week and try it out first which was cool.
It monitors and streams 88 functions of the engine live on a 4" colored screen and does graphs. I haven't, as of yet, used it to it's full capability as it also does the Transmission, ABS, and Airbags.
For those looking for a little more than just a code reader, it's a good buy and supposedly works on all Asian, European, and American gasoline vehicles from 2001 on to I believe 2017 and diesel from 2004 on. It updates via a computer and USB cable.
Features:
  • Retrieves Manufacturer Specific Enhanced Data for Domestic, Asian and European vehicles
  • Reads and Records Data Streams for ABS, SRS, Transmission and Engine
  • Auto ID Vehicles, Auto Module Search & Fast Protocol ID
  • Reads and clears codes on Engine, Transmission (A/T), ABS, and Airbag (SRS) systems – on all makes and all models (16 Pin)
  • Support for all 10 test modes of OBD II with Enhanced OBD II Mode 6
  • Retrieves generic and manufacturer specific codes – Current, Permanent & Pending
  • View freeze frame data and I/M Readiness monitor status
  • Graph, record, and replay data in full color
  • Menu with DTC definitions in English, Spanish & French
  • Intuitive Interface and Button
Old Nov 20, 2021 | 09:30 PM
xalty's Avatar
rotunda vcm
Old Nov 30, 2021 | 02:41 PM
xjack's Avatar
mongoose clone, loads of fun
Old Dec 1, 2021 | 09:03 PM
cubster2000's Avatar
Just got my CRP 123 Premium off the UPS truck today from Amazon. I downloaded the updater software, updated with the latest modules (including the Jaguar one), and connected it to my 2003 XJ8 and...it gave me a connection error. Tried it a few times, then took it over to my wife's RAV4. It worked fine on there. Grrr. I'll give it a try again tomorrow, but, poor start here.
Old Dec 2, 2021 | 02:48 AM
xjack's Avatar
it may need some special sequence in order to connect, for example first set key position to second and then connect scanner, if they list it as compatible you can always ask them for guidance.
Old Dec 2, 2021 | 08:08 AM
60Gunner's Avatar
Not the case. I've connected it even with my XJ8 Sport already running. I've also connected it first, then turned the key to the second position.
He may have one of several fuses blown associated with the port on his car. I forget which ones but as I recall there's one in each fuse block in the rear kick panels and one in the trunk.
Or possibly bent pins.
It works great on my car. It's obviously not the scanner.
Old Dec 3, 2021 | 01:24 PM
Jtestrake's Avatar
I bought this Launch X431 for my Maserati and found that it works fine with my ‘06 XK8 and my ‘00 XJ8. It’s not cheap but it reads all the modules just fine.
LAUNCH X431 PROS Mini 3.0 (Same Function as X431 V+) Bi-directional Scan Tool OE-Level Full System Automotive Diagnostic Scanner 31+ Service ECU Codin
Amazon Amazon
Dan Fuller
25
Sep 18, 2020 08:29 AM
Vincesandoval718
Jun 29, 2019 06:31 PM
peterv8
Sep 28, 2017 11:30 AM
mkontos
Jan 25, 2016 11:45 AM
Six Rotors
Aug 21, 2012 03:48 AM
