dicque
Old Jan 27, 2016 | 06:35 PM
Mikey's Avatar
Be aware that disconnecting/reconnecting the battery will erase P1111 and set P1000 which means you'll have to drive long enough to reset all the monitors.
Old Jan 27, 2016 | 07:32 PM
sparkenzap's Avatar
Thanks for a more complete picture!
It is certainly worth checking the battery. The running voltage apparently does not give the whole story because of ripple , which does not show up on a meter. If the engine off voltage is lower than 12.4 volts, or if the battery is 4 or more years old, you might consider replacing it.
The ABS module has fault codes that can be read with dealer level software. The normal failures causing the ABS faults are battery voltage, bad wheel sensor or circuit, or the motor circuit. Check the archives for how to fix the ABS motor connector.
Old Jan 28, 2016 | 11:33 AM
Dicque's Avatar
Thanks sparkenzap,
I will look at this as well dod not have time to check out the car until tomorrow. Will get back to you then.
All the Best!
Dicque
Atco
Feb 4, 2016 07:55 AM
geewilicurs
Jan 31, 2016 05:21 PM
Phil3814
Jan 28, 2016 09:09 PM
Addicted2boost
Jan 24, 2016 05:35 PM
Chuck Schexnayder
Jan 21, 2016 12:38 PM
