Differences 305 vs. 325 mm brakes?
Old Nov 13, 2019 | 08:29 AM
Z07Brandon's Avatar
So did all 2000-2003 xj's come with 325mm fronts? That is, excluding the R1 and xjr100.
Old Nov 13, 2019 | 05:02 PM
Highhorse's Avatar
No, mines a 2000 VDP (with R pkg) and mine came with 305's. I would guess its an option pkg.
Old Oct 13, 2020 | 10:10 AM
Terryble's Avatar
Originally Posted by John Amaradia
Hello, rekindling the ol' 305 vs 325 brakes. Proud warper of discs here, 305s (Mintex). I did read all the posts (and recommended links) but I don't seem to find the answer, maybe you guys could please clarify...
So case in point is a 1998 x308, vin starting with 856, 17" Celtic Alloy wheels. My questions are:
1. Would the 325 disc fit the wheel ?
2. Do I need to change the calliper (in relation to the disc and/or wheel) ?
3. Is it worth moving to performance parts such as this one or this one?
Many thanks for your patience and help!
John Amaradia,
Maybe this post is too old but here it goes;
I have a 2001 Jaguar X308 3.2 V8 Executive Sport and I just checked to be sure before ordering new discs. My front brake discs were 305mm / 12 inches. I think the 325mm discs would not fit within the stock brake calipers.
Old Oct 13, 2020 | 09:14 PM
M. Stojanovic's Avatar
Obviously not as the calipers have to sit 10 mm further away from the hub cetre. These are the calipers for 325 mm discs:
Old Oct 17, 2020 | 10:58 AM
nilanium's Avatar
The calipers and pads are identical between 305 and 325 rotors, the only differences are in the caliper mounting bracket.
Old Oct 17, 2020 | 12:44 PM
Terryble's Avatar
Talking
Oh didn't know it was only the caliper mounting bracket, thanks!
Old Dec 5, 2023 | 06:57 PM
Mguar's Avatar
Originally Posted by Mvirgil
That's quite a history of warped rotors. If its not driving style; then check your calipers and pad wear for even wear/stiffness.
My 98xjr had braking issue (305mm disks), directly related to played calipers and enthusiastic driving habits... Prompting an upgrade to R1 calipers and rotors.
Once rotors get to the glowing stage warpage is common. That’s the reason a lot of us go to full floating discs. While you might get get away without warping the overheated rotors with a proper cool off lap. I got tired of replacing the rotors.
Old Dec 6, 2023 | 02:05 PM
  #28
Sean B's Avatar
Why does it happen? Possibly under braked for the platform, hence the bump in diameter.
The warping was pretty much solved with one member posting the warped disc phenomenon years ago, coming down from speed to a stop and hold of the discs. Next repeated brake from speed had introduced the warped bumping pedal....holding the hot rotor had created a hot spot and the warp. Bigger brakes is for me the very best upgrade on any car you can do, just don't pin hot discs!
Old Dec 6, 2023 | 03:37 PM
dangoesfast's Avatar
That's an easy one - the part of the rotor where the pads are in contant cools at a different speed to the rest of the rotor, which leads to warp... that's not the *only* reason for warp, but in the specific scenario you describe that's what's happened. In cars that use the regular calipers and pads for the handbrake (most cars these days), parking the car with the handbrake on after a spirited drive can easily warp the rears.
Old Dec 6, 2023 | 08:03 PM
  #30
Addicted2boost's Avatar
Any X308 with the 305’s are definitely too small. It’s just like the 98 X308’s that have the smaller front diameter wheel bearings. It’s just too small for the car. When I rebuilt the entire front suspension and subframe of my 98’ XJR about 5 years ago, I replaced the knuckles with an 02’ XJ8. The had the larger wheel bearings.
Old Dec 7, 2023 | 01:24 AM
  #31
Stu 1986's Avatar
When I bought my first X308 in 2009 it was a 4.0 Sovereign and soon after buying it became apparent that the front brakes were warped. The dealership wouldn’t let me test drive the car because I was only 22 and they didn’t think I was in a position to buy the car. Anyway, after that regardless of what I’m driving when stopping from high speed I always aim to leave a big enough gap between myself and the other vehicle so I can allow the car to crawl forward and not create a hot spot on the discs.
My current XJR has warped discs and I will be replacing them soon, but this time I was able to knock that off the price.
Old Dec 7, 2023 | 09:22 AM
  #32
Ken Cantor's Avatar
or you could put the car into neutral (assuming you’re on level ground ).
Old Dec 7, 2023 | 12:34 PM
  #33
Stu 1986's Avatar
I was taught to leave automatic transmissions in D and hold on the brake if stopped for shorty periods like traffic lights, if stopping for longer periods then take it out of gear. It says as much in the X308 owners manual, plus on the NA cars with the ZF5HP24 unit it helps avoid damage.
mshedden
Apr 8, 2018 05:43 PM
calvindoesntknow
May 22, 2015 10:39 AM
XKRNorway
Mar 14, 2014 08:50 AM
adam699
Apr 6, 2012 02:06 PM
crocodile62
17
Apr 13, 2010 03:00 AM
