Dilemma, Cam bearing caps ...
Old May 4, 2016 | 03:26 AM
ericjansen's Avatar
Default Dilemma, Cam bearing caps ...
So I finished doing my secondary tensioners, but upon loosely installing everything, I noticed the front passenger side cam bearing cap was reversed (pointing backwards).
I first thought I had a mistake myself, but upon checking the pictures before the disassemble, I found it was already like that.
Now, should I install it as I found it, or flip it to the original assembly position?
Car has done ~69.000 miles, of which the last 9k by me.
There are no wear signs on the cap or cam.
E.
Old May 4, 2016 | 07:16 AM
avern1's Avatar
Since the cap is the bearing half I would reinstall as it originally was.
Old May 4, 2016 | 03:03 PM
sparkenzap's Avatar
I would carefully check the concentricity in each orientation!
Apr 17, 2016 05:30 PM
srpope80
Nov 17, 2011 04:06 PM
majbill
Apr 20, 2010 07:43 PM
Earnest
Dec 9, 2009 07:22 PM
b33fh4mm3r
Mar 10, 2009 11:22 AM
