Does anyone know...
Old Jul 7, 2013 | 08:51 PM
Donzi's Avatar
Default Does anyone know...
For sure.. if you can simply swap out the ECU from one XJR to another without any programming issues. Assuming the ECU came from the same year and model?
Old Jul 7, 2013 | 09:12 PM
sparkenzap's Avatar
I know for sure you cannot unless you were to change keylock tumblers too. You will need the key transponder married to the ecu by the dealer software.
Old Jul 8, 2013 | 07:35 AM
Donzi's Avatar
Ok, thanks!
Old Jul 8, 2013 | 10:50 AM
xjrguy's Avatar
Actually, you can make another ECM run the car, but it will never be 100% "right". For instance, at that point you'll have a car that will never pass a Gov't required inspection because it will have the wrong VIN # in the module. If you try to program it to correct the VIN, you will have a brick.
A module with the correct part number can be made to operate the car, by running the immobilization app in SDD to sync the security system so the PATS System will allow cranking and fueling.
Cheers,
Old Jul 8, 2013 | 03:08 PM
sparkenzap's Avatar
So, Steve:
What does the dealer do to make the new ECU "right"?
Old Jul 8, 2013 | 04:09 PM
xjrguy's Avatar
So, Steve:
A new unused ECM is programmed as a new module. Doing that burns things like the VIN, PATS keys and wheel size into the new part. From then on, the only thing that can be done is configuration changes. If it is ever again programmed like it's a new, blank module, it's toast. It can be moved to a comparable car, but all you can do is sync the PATS and security system so the car will start and run.
In other words, there is no way to make a used ECM "right" in another car.
Make sense??
Old Jul 8, 2013 | 04:41 PM
sparkenzap's Avatar
Yes, but wow...
I guess that only screws you if you have emission control testing or you sell the car, huh?
Juke
Jun 2, 2015 01:39 AM
TXJagR
May 20, 2015 06:26 PM
Juke
Dec 14, 2014 09:33 AM
cbharley10
Jul 3, 2012 07:15 AM
JOsworth
52
Dec 29, 2011 03:02 AM
