Does anyone know how to erase the "homelink" codes?
Old Nov 18, 2012 | 04:32 AM
SirJag's Avatar
Default Does anyone know how to erase the "homelink" codes?
... in an XJ8? I programmed it to open my garage doors and now I want to remove all programming from all 4 buttons.
Thank you!
SirJag
Old Nov 18, 2012 | 04:58 AM
If the XJ8 programing procedure is the same as the XK8, erasing all the programmed transceiver buttons is done by:
1. press and hold the two outermost buttons until the indicator light begins to flash after 20 seconds
2. release both buttons
This puts the transceiver back in learning mode.
Here's the full setup procedure from the XK8 Handbook. I don't have the equivalent XJ8 Handbook section.
If this isn't the same for your XJ8, I'll dig deeper for the information.
Old Nov 19, 2012 | 02:11 AM
SirJag's Avatar
Attachment 26256
Attachment 26257
Attachment 26258
Thanks so much, Graham!
SirJag
Old Nov 19, 2012 | 01:00 PM
danielsand's Avatar
Correcto! X308 is the same.
Old Nov 30, 2012 | 09:13 PM
hoffmanlisa's Avatar
I'll try that at home. Thank you. It will help me a lot
Old Jul 1, 2013 | 02:51 PM
Donzi's Avatar
Thanks guys! This just helped me too, shows how doing a search before just posting works well most of the time! Cheers.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
mrplow58
Sep 24, 2015 08:05 PM
