Don't Put off Timing Chain Tensioners!
Old Feb 24, 2015 | 07:14 PM
okXJR's Avatar
Default Don't Put off Timing Chain Tensioners!
It's been said before, but your XJ is living on borrowed time if you haven't done your tensioners!
Mine supposedly has slightly better materials than earlier cars being an '00 XJR, but look at the cracks!!
Well worth the time and money.
Attached Thumbnails Don't Put off Timing Chain Tensioners!-img_3495.jpg   Don't Put off Timing Chain Tensioners!-img_3490.jpg   Don't Put off Timing Chain Tensioners!-img_3496.jpg   Don't Put off Timing Chain Tensioners!-img_3501.jpg   Don't Put off Timing Chain Tensioners!-img_3497.jpg
Old Feb 24, 2015 | 07:45 PM
macs99's Avatar
Just had mine done on my xk8 with 68000 on clock, tensioners looked fine, guides were cracked in a dozen places dont know what was holding them together luck i think good luck on your car.
Old Feb 24, 2015 | 08:26 PM
retromotors's Avatar
Help me out here .... I'm a little confused by the pics.
Your pics 1 -3 are pretty self explanatory, but what's happening with the other two?
Pic 4 shows collection of parts. I'm seeing what appears to be original style primary tensioners, but later metal-bodied secondary tensioners?
Pic 5 shows what appears to be an original primary tensioner. I realize these need to be replaced regardless, but if the image was supposed to show specific damage or failure, I'm not seeing it.
Just curious.
BTW, thanks for taking the time to document and post this.
Regards,
Retro
Old Feb 25, 2015 | 07:21 AM
okXJR's Avatar
Just curious.
Regards,
Retro
Hi Retro,
Everything actually looks good except the guides, which are badly cracked. My original primary tensioners look OK, but I've seen them badly cracked as well.
Happy motoring.
Old Feb 25, 2015 | 08:02 AM
Daim's Avatar
This is already on my list... My 3.2l has just covered 145k km (so around 80k miles) and runs very quiet. No chain rattle at all... And being a 1997 I assume it has either been done some time OR it is a newer engine. I will still be doing them... Better twice than never!
Old Feb 25, 2015 | 05:48 PM
okXJR's Avatar
Yes, it's nice not having to hold your breath every time you start the car! (Even if it was done twice!)
Old Feb 25, 2015 | 08:54 PM
XJDanny's Avatar
I just had my tensioner's replaced last weekend. I have an 02 XJR so I had the second generation with the springs. I have 64k miles. The old tensioners actually looked pretty good but one of the springs was frozen. I'm not sure what bad things a frozen spring can cause but I'm really glad I changed the tensioners and its behind me. I put it off too long!
Old Feb 26, 2015 | 06:31 AM
RJ237's Avatar
With that low mileage it's unlikely they were changed or the engine replaced. Best to get the right side valve cover off and take a look.
But keep in mind that there have been a couple of instances where only one was replaced, so a metal body on the right side is no guarantee.
Old Feb 26, 2015 | 08:00 AM
Daim's Avatar
Like said, they are on my list to do So I'll be tackling them in Summer... Got to get the rust off before I can do anything else
Old Feb 26, 2015 | 08:42 AM
RJ237's Avatar
There have been a lot of sad stories from people who put it off and kept driving. I wish you luck.
Old Feb 26, 2015 | 04:14 PM
rocklandjag's Avatar
Strongly Disagree - you need to do the tensioners before anything else
xjrjag
Nov 27, 2025 09:16 AM
celticpiping
Sep 18, 2015 06:17 PM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
souldoubt
Aug 25, 2015 08:15 PM
