Are the door lock buttons removable (unscrewable?)
Old Feb 17, 2014 | 02:42 PM
buckshaw's Avatar
Default Are the door lock buttons removable (unscrewable?)
Does anyone have knowledge or first hand experience removing (from a XJ8 sedan, circa 2001) the chrome push down - pull up door lock buttons? I've tried, unsuccessfully to unscrew both front and rear, counterclockwise using only hand power with a rubber jar lid helper. I'm reluctant to try with pliers in case they in fact are NOT supposed to be removed. Any advice would be appreciated.
Buck Shaw
Old Feb 17, 2014 | 04:12 PM
avt007's Avatar
Why do you want to remove them? I have had the doors and locks apart a couple times, and there's no need to remove the knobs.
Old Feb 17, 2014 | 08:24 PM
buckshaw's Avatar
No door or lock work planned at this time. I'm considering replacing them (the door lock buttons) with a different style, IF they are removable.
Old Feb 18, 2014 | 02:54 PM
Mmutch's Avatar
In the uk on my 1997 XJ8 sovereign LWB they unscrew easily by hand without any tools just took a while as there fairly long threaded if it helps
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
AL NZ
Sep 4, 2015 08:39 PM
