Drive Shaft Removal in order to get to fuel lines
Old May 13, 2018 | 09:05 PM
ColeD's Avatar
Default Drive Shaft Removal in order to get to fuel lines
good evening fellow members- I am attempting to replace fuel pumps on my 2000 xjr- and have decided to follow the tank removal method- in searching the forums I have found great advice and instructions- some of the instructions call for removing the drive shaft and the brake cable in order to get better access- has anyone had any experience with the drive shaft removal- I have seen posts that reference marking it - can anyone expound on that - I am hoping to get some better directions how to handle that driveshaft situation before I tear into it - thanks for any all help. Cole
Old May 13, 2018 | 09:27 PM
motorcarman's Avatar
You can disconnect the propshaft from the diff and handbrake cable threaded rod to gain more access. Just position them out-of-the-way.
bob
Old May 14, 2018 | 09:58 PM
ColeD's Avatar
Thanks Bob- the bearing carrier would need to be loosened as well correct? thanks again Cole
Old May 15, 2018 | 08:09 AM
If the splined section will collapse enough to remove the rear JURID connector, then leave the center carrier alone. The U-Joint will allow the shaft to tilt out of the way.
bob
Old May 15, 2018 | 05:46 PM
ColeD's Avatar
Bob thanks for the information- one additional question I have read about marking the fitting - I am not clear on that should you mark a specific hole or mark the jurid for a specific way it goes back together- thanks for all of your help - Cole
Old May 15, 2018 | 08:54 PM
Marking the flange is about propshaft balance. I don't really worry about decades old cars with wear and distortions in the JURID coupler being a concern.
You can mark it if you want.
bob
Old May 15, 2018 | 09:25 PM
ColeD's Avatar
Thanks Bob I want to do it right and dont want to over complicate what is already a challenging job getting the tank out and getting the hoses disconnected from the tank seems to be a challenge without a lift- I am putting it up on jack stands to support and going underneath- thanks to you and the forum I will have a lot of good advice to get it taken care of. Thanks again Cole
Bogbrush
Feb 5, 2016 07:03 AM
afterburner1
Feb 16, 2015 03:56 PM
o1xjr
Apr 16, 2014 10:09 AM
carcster
Mar 11, 2014 12:49 AM
penguin
Mar 18, 2013 12:10 PM
