Driver door module and lock security tumbler questions
Old May 5, 2025 | 07:19 PM
SublimeXJR's Avatar
Default Driver door module and lock security tumbler questions
So I have an intermittent driver's side front power window. From researching the forums it appears to be either a bad module or as some folks have noted potentially a bad part of the security tumbler in the door lock? I have tested my motor and it works. Disconnecting the battery to reset the door module fixes it, but it is a pain to do every couple of weeks. What is involved in replacing what has been referred to as the "security tumbler" or is there a fix for it? Was thinking I would start there rather than start by replacing the door module? Or should I do the reverse? Thanks.
Old May 5, 2025 | 10:08 PM
Peter_of_Australia's Avatar
"intermittent" in this connection triggers 2 more possibilities in my mind:
1. A cold weld (i.e. a solder point on a module, which "broke" over time and as such conducts electricity now only sometimes).
2. As switch engineer, I always suspect switches: Oxidized contact surfaces inside of the switch could also lead to that behaviour.
Old May 6, 2025 | 05:29 AM
RandyS's Avatar
Poor contacts are almost always my first thought on intermittent electricals.
Sometimes you can clean them up and it works for a while, and sometimes
you cannot seem to find the problem to clean it up. That's when most just
install a new switch and call it good.
dwilmot
Aug 10, 2023 11:21 PM
Ant Buck
Feb 2, 2023 04:14 PM
rupertle
XJ40 ( XJ81 )
Dec 28, 2019 11:08 AM
rupertle
XJ40 ( XJ81 )
Mar 17, 2012 01:36 AM
David Type S 01
Aug 29, 2010 03:53 PM
