Driver door wont lock at all.
Old Aug 31, 2019 | 05:14 PM
RA110623's Avatar
Banned
Default Driver door wont lock at all.
Hi im facing problem here i can't lock the driver door by the key or by the remote i can lock and and unlock the 3 doors by the remote but it doesn't work on the driver door .
I disconnected the negative battery cable for 5 minutes it didn't work. Where should i start to fix this problem?
Thanks.
Old Aug 31, 2019 | 07:00 PM
Highhorse's Avatar
Do you hear an activation in the doors when using the remote?
If so, your plastic linkage retainer may have broken? This is what you'll see after you remove the door card to investigate it....
Old Aug 31, 2019 | 07:17 PM
RA110623's Avatar
Banned
Hi ray. No i don't hear any activation the doors works fine except the driver door wont look . I read in some threads there's 25amp fuse near the pedals or under the seat it might be the problem but can't find anything there
1JerryL
Jan 5, 2018 09:08 AM
jewsonlot
Nov 30, 2014 03:10 PM
bradstuff
Sep 10, 2014 01:43 AM
Harryk
Mar 2, 2012 04:29 PM
Igloo112
Oct 18, 2008 10:37 AM
