Drivers door won’t lock
Old Dec 22, 2017 | 03:51 PM
Eddie602's Avatar
Default Drivers door won’t lock
My drivers side doors won’t lock , both of them just stay open when I click on the transmitter for them to lock . The passenger side doors lock also the trunk and gas door latch lock as well , ?!
Old Dec 22, 2017 | 04:14 PM
Lady Penelope's Avatar
Try removing the + battery terminal for a minute and see if the security and locking ECU resets to zero state and if not try a " Hard Reset "
Old Dec 23, 2017 | 12:00 AM
King Charles's Avatar
+1
Hard Battery Reset :
With a 10mm wrench loosen & remove the negative lead to the battery, touch it to the positive post. This drains all residual voltage in capacitors. Re-attach & tighten the negative cable.
Old Dec 23, 2017 | 12:40 AM
Right doors lock actuator fuses : # 13 and #15 / 25 amp RH heelboard fuse box
Left door lock actuator fuses : # 13 and # 15 / 25 amp LH heelboard fuse box
Old Dec 29, 2017 | 04:23 PM
Jaguarstyper's Avatar
Try the key
Old May 21, 2021 | 08:28 AM
nerf's Avatar
Thumbs up
just wanted to add my thanks .. this fixed my passenger door after it stopped locking/unlocking.
carzaddict
Sep 19, 2023 11:09 AM
Sentinelist
Mar 14, 2023 02:25 PM
TreVoRTasmin
Dec 28, 2013 10:11 PM
facet
Dec 15, 2011 02:50 PM
newuser
Apr 5, 2010 04:13 PM
