Drives shaft bolts
Old May 1, 2020 | 12:17 PM
owas's Avatar
Default Drives shaft bolts
This is going to be abit of a stupid question but it's been a while since I took it apart and don't remember.
The bolt head should be on the rear of the jurid coupling to the drives shaft flange right? So the nut is facing you in this pic.
If that's correct, how do I get the bolt in from the back, doesn't seem to enough space to get it in?
Old May 1, 2020 | 01:13 PM
owas's Avatar
Just realised I was supposed to put them through before bolting it to the diff,
What do I do now
Old May 1, 2020 | 01:34 PM
motorcarman's Avatar
UNBOLT, slide propshaft forward, install bolts, tighten bolts.
I always leave the JURID flange on the propshaft.
bob
Old May 1, 2020 | 02:18 PM
owas's Avatar
bob
Got it!
Didnt realise I had to unbolt the center bearing plate to get it to slide lol.
Old May 1, 2020 | 09:22 PM
The spline joint is on the gearbox side.
bob
orangeblossom
Oct 12, 2019 01:02 AM
harvest14
Jul 30, 2019 07:35 PM
luka000
Nov 6, 2018 03:49 AM
timsalyer
Nov 28, 2013 01:22 PM
2000CAXK8
General Tech Help
Oct 23, 2012 02:25 PM
