DTC P0172 and P0406
Old Jul 18, 2012 | 06:51 PM
ant17's Avatar
Default DTC P0172 and P0406
?I get these two codes intermittently, even a RP at one time.
I have an idea what they are.
Should I try fuel injector cleaner first?
The 0406 was listed as fuel level sending unit problem.
I better get gas!!
tia
Old Jul 19, 2012 | 05:26 AM
jimlombardi's Avatar
Hi
Look at this other thread on P0406 DTC (post# 2 issued resolved by clean throttle plate):
https://www.jaguarforums.com/forum/x...e-p0406-37677/
I would try cleaning Throttle body and its electrical contacts, also MAF.
Here is a PDF about cleaning Throttle body, MAF and the Part Load Breather (for XK8, but most of it also applies to XJ8) 2 links (try #1 first, if no go, use the second weblink):
http://205.196.123.8/auxklm9ttxcg/tb...d.Breather.pdf
Free Cloud Storage - MediaFire
This PDF file was on the Max Performance Cars website (the website does not seem to be online anymore).
When I tried to add this PDF as an attachment here on the forum, it failed to upload (2.68 MB).
Jim Lombardi
Old Jul 20, 2012 | 05:02 AM
ant17's Avatar
Thanks!!
I made an error the 0406 is 0460.
sorry.
thanks
Old Jul 20, 2012 | 05:21 AM
Hi Antony
Another thread that mentions P0460 recommended to have a full load test on your battery.
Apparently the battery can cause the ECU to generate a P0460 DTC code.
Jim Lombardi
trosty
26
Dec 18, 2022 06:40 PM
caveforce
38
Nov 16, 2015 10:19 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
