EGR valve
Old May 25, 2008 | 06:36 PM
skanoski's Avatar
Default EGR valve
I was doing some spring cleaning today (98 XJR) - cleaned the MAF and throttle body (no biggie), and also the EGR valve, which took a bit more time. After putting everything back together, the car starts OK and then dies immediately. Is this a sign that I may have screwed up my EGR valve somehow? I not sure what the symptoms are for a shot EGR valve. It was horribly dirty with carbon deposits - now it's clean, but I'm stuck in the garage.
Old May 28, 2008 | 05:02 PM
skanoski's Avatar
Default RE: EGR valve
I'm pretty sure no one was losing any sleep over this post - nevertheless, I thought it was worth posting the outcome. It turns out the 'quick-release' T-connector for the part-load breather had come off (where it connects under the throttle body), so the car was stalling immediately due to a large vacuum leak. For some reason it's not latching on as it should, even thought the connector is not broken. I just pushed it in as far as it would go, and that seemed to do it.
Old May 28, 2008 | 07:06 PM
ibjags's Avatar
o rings for part load breather at T conector probaby swollen or damaged
remove conector inspect o rings, if ok use some spray silicone on the o rings and then reinstall
make sure its fullyseated to avoid furtherissues down the road
Old May 30, 2008 | 06:35 AM
FactoryJaguarTech's Avatar
Lol common problem when people remove their throttle.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
