EGR valve cleaning
Old Jan 22, 2013 | 07:44 AM
Roger77's Avatar
Default EGR valve cleaning
Hi All,
Well what started as a cam cover gasket replace to fix an oil leak is turning into a OH SH*T that needs fixing too !!!
I read that the VVT engines do not use an EGR valve, and S/C engines do, so knowing from experience with a Mustang that at 200K miles the EGR valve might be a "little dirty" I thought I should take a look. It's located under the throttle body on the rear of the inlet elbow.
I'm also replacing the part load breather tube with something a little better than the plastic crap Jaguar uses.
Here is what I found.
View from top of inlet elbow with throttle body off
Took off the valve and started by tapping lightly to dislodge debris
Then carefully (with a rag in the blower inlet) I cleaned out the elbow port.
This is what I got out (the hole was almost closed with this crap)
So if you have a high mileage XJR I suggest you service the EGR valve, if the larger pieces dislodge and go into the engine they will cause damage.
Old Jan 22, 2013 | 09:20 AM
Sean B's Avatar
Can't see your pictures Roger, but from what you said I can totally agree about the EGR inlet being coked up - that's why I deleted mine
There's some info and posts on the subject in the s type forum look for the posts by Avos. One more thing to forget about once done in my book.
As a polite suggestion, use a new gasket under the throttle, you know the metal crush one, because if you don't there's a chance of unmetered air leaks that will drive you mad.
Old Jan 22, 2013 | 10:06 AM
dsnyder586's Avatar
Roger- if you could get the pics I would appreciate it, I will have to tackle this while I am at it this spring.
Old Jan 22, 2013 | 11:09 AM
Roger77's Avatar
pics are showing up in my post ?
Old Jan 22, 2013 | 11:11 AM
Roger77's Avatar
does this help?
roger77_photos's Library | Photobucket
Old Jan 22, 2013 | 11:36 AM
dsnyder586's Avatar
Very much so- thank you!
silkcat
Jan 18, 2025 04:29 AM
bamforp
Aug 14, 2024 05:36 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
jaaag
Sep 11, 2015 12:53 AM
XFR_Gold
Sep 2, 2015 12:24 PM
