Electric windows buttons - driver's door central control pad
Old Jan 5, 2018 | 02:39 PM
Londonroader's Avatar
Default Electric windows buttons - driver's door central control pad
The driver's door central electric windows button pad on my 1999 v8 sovereign just started to warm up and get quite hot during a long drive.
all the windows still responded to the controls however.
No warning lights have come on.
would anyone know what (electrical?) fault may be happening?
Old Jan 5, 2018 | 03:08 PM
Highhorse's Avatar
Sounds like just a switch going bad or grounded. I would be pulling that asap to check it and prevent any kind of fire.
Old Jan 6, 2018 | 05:53 AM
Default Electric window switches thanks
Thanks for this HighhorseI will have a look.The truth is i had the whole door panel including arm rest off recently, (and un-necessarily) while replacing the door mirror assembly which had been broken off by a drive by vandal.I didnt think i had messed with the wiring and its been a month since then anyway.
Old Jan 6, 2018 | 07:10 AM
Highhorse's Avatar
Understood, too bad about the vandal (soulless scum).....but for your part, you may had inadvertently pinched a wire and after a bit of rubbing, it wore through? It may not had been anything on your part either other than moving a 19yr old part that's dry rotted, it cracks and creates a bridge between what was two separate insulated pieces. Definitely doesn't hurt to check.
Old Jan 6, 2018 | 10:59 AM
motorcarman's Avatar
I wish people would read the TSBs that are posted here on this site and on Gus's site.
TSB 501-46
Common complaint up to VIN F11700.
I'll post it so nobody complains that they cannot find it!!!!!!!!!!!!!!
bob
Old Jan 6, 2018 | 01:56 PM
Highhorse's Avatar
Isn't that why your here Bob? ....never mind, don't answer that.
Old Jan 6, 2018 | 05:45 PM
Isn't that why you're here Bob? ....never mind, don't answer that.
I guess that is my lot-in-life.
I never really have to type in answers to questions because Jaguar already knew about the fault and sent out TSBs to the Dealer Techs!!!!!!
All I have to do is remember that there was a TSB issued and find it in my TSB info folders. Someday my memory will fade and I will just read posts!!!! (or make up answers to sound smart??)
bob
Old Jan 6, 2018 | 10:23 PM
Highhorse's Avatar
I need to buy you a beer if I make it back out that way.
Old Jan 7, 2018 | 05:09 AM
Default Many thanks both
Thanks for this Bob/highorse,
i had not been aware of tsbs!
now i must go and find some 50 Milliamp bulbs
Incidentally i now realise that when i got in the car mid-journey the other day, my seat had moved to a forward position that was certainly not something I had set (i have never knowingly used the seat position presets) so I imagine there is more to come....
XJ8JR
Jan 15, 2018 03:06 PM
