Electrical problems after sitting for 13 years..
Old Oct 15, 2025 | 01:34 AM
Vauxi's Avatar
Both joints look suspicious. Ask him do to both.
Old Oct 15, 2025 | 02:03 PM
David N. Warner's Avatar
This is from the cluster from my 2000 VDP. The board layout looks a bit different. Manufactured on Feb of 2000.
Old Nov 6, 2025 | 11:11 AM
mr.sandcast's Avatar
Hi everybody,
I finally was able to get to the car again. Cleaned 8 or 9 ground points, which were not really bad, worked on the cluster board, and: no difference. I really believe the abs-brain went south, and also the cluster.
I also checked the wiring of the 5th cylinder, haven't found anything suspicious. So no progress at all.
I need to find somebody who would be able to fix the cluster, and also I would like to buy a working abs brain. Anybody knows anything?
Thanks, cheers, Herman
Old Nov 6, 2025 | 05:35 PM
Parker 7's Avatar
There is a bad soldier joint on the X300 ABS module where there is a DIY repair , may apply to the X308 as well
This shows with a C1065 or C1095 code abouts
Old Nov 7, 2025 | 12:25 AM
Good Morning,
I checked this already, and fixed it. No improvement.
Interestingly my scanners don't show error codes. I read somewhere there could be another problem if the codes don't show up when scanned... anybody knows about this problem?
Cheers, Herman
Old Nov 7, 2025 | 06:02 AM
Vauxi's Avatar
What modules you'r tester connects to? What does it say on those it would not connect?
Old Nov 27, 2025 | 03:03 PM
Hi everybody,
just to keep you posted:
I was able to obtain a used brain for the ABS-system, and put it in, no improvement.
I decided to get the instrument cluster repaired to see if I will see some improvement here.
Should have it back by the end of next week. I hope to make some progress then.
Old Dec 4, 2025 | 01:12 PM
  #28
Default Next step done..
Hi,
just received a call from the expert where dropped off my cluster..the main processor on the board went south.
So I need to find another cluster, or a new processor.
Does anybody know where the mileage of the car is stored? Afai heard it's not in the main processor, is this right? Or, does anybody know an expert who would be able to fix my cluster?
Last question: is it possible to set the mileage to the correct if I find a used cluster?
thanks, cheers, Herman
MarcoB
17
Apr 4, 2025 09:08 AM
The Flannell
Jun 19, 2023 02:36 AM
xj-c4.2
May 16, 2021 09:28 PM
CozDan19
Jul 6, 2015 12:11 PM
ArtyH
Sep 29, 2013 10:27 AM
