Electrical/Steering wheel problems
Old Jul 19, 2010 | 01:51 PM
ocphippsjr's Avatar
Unhappy Electrical/Steering wheel problems
My 2000 XJ8 steering wheel moves or doesn't move(Only The Shadow knows) and is not responsive to the control button. Memory settings are sporadic. There is a clicking from the right side of the dash.
Suspect the Body Control Module may be the culprit. How do I get to it? Just remove the Glove box or airbag or what?
Olen
Old Jul 19, 2010 | 05:14 PM
test point's Avatar
The steering column tilt/reach operation is a reoccurring problem associated with the tilt/reach potentiometers and drive cables. Either the lubrication of the column thickens over the years and stops the motion or the pots develop a dead spot, or the pots do not indicate the end of travel and cause the motors to strip out the flex cable(s).
The tilt motor/pot/cable is easy to get to, the reach motor/pot/cable less so. Do a search on 'tilt' and/or 'reach' and you will find several discussions on the subject.
Probably not associated with the BCM.
Old Jul 24, 2010 | 10:25 AM
ocphippsjr's Avatar
Smile thanks
Thanks, new info.
I'll check within my ability. I got and promptly lost a pot for the function. Will still try to find one.
Thanks again
Olen
Forcedair1
Sep 8, 2025 01:57 PM
prettydaim
Mar 28, 2021 07:47 AM
PMKimpton
Aug 3, 2019 08:22 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
