engine/abs/traction/asc - problems
Old Aug 19, 2015 | 03:18 AM
tjcd.davis's Avatar
Angry engine/abs/traction/asc - problems
2001 Jag X308
ABS / TRACTION / ASC WARNING LIGHTS
What next ? - Any suggestions appreciated
Have replace all 4 wheel sensors - Electrical cables look good
Removed ABS module
Re soldered 2 connections - which didn’t look dry jointed
Some rust evident between module and pump - face of pump body - it cleaned off easily
Pump seems to be working - noise when doing start up check
Pressure bled brakes - is there any indication that ABS is working ?
Started car still have all warning lights on - brakes seem to work okay and car drives changes gear and stops fine.
What now - change the complete ABS module and pump or change the wheel relucter wheels
Or scrap the car - loved the xj6 series 3 and xjs
TREV-tjcd.davis
Old Aug 19, 2015 | 05:34 AM
sparkenzap's Avatar
I suggest having the ABS codes read with dealer level software before throwing more money at part replacement.
Old Aug 19, 2015 | 01:15 PM
motorcarman's Avatar
+1
bob gauff
Old Aug 20, 2015 | 01:46 PM
tjcd.davis's Avatar
Thanks took your advice - had diagnostic done by Halfords workshop
They found fault on sensor lead and repaired it - car passed MOT.
Great service - MOT test £35.00 + Diagnostic £35.00
Worth trying much cheaper than Jaguar Dealer
Thanks for your help
td
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
