Engine burning oil
Old Dec 28, 2007 | 03:27 PM
drog321's Avatar
Default RE: Engine burning oil
Cars don't naturally "burn oil" unless there's a leak. I just had a tune-up and my car was leaking oil in to the spark plugs. I had some gaskets replaced.
I had a slight burning oil smell before, but now it's gone.
Old Dec 28, 2007 | 04:10 PM
drog321's Avatar
Couldn't tell you...A)mine never had oil on the ground under the car, not even a dropB)I'm not a mechanic myself.
I had a helluva performance increase in the past 24 hours after getting problem fixed though.
Old Jan 1, 2008 | 08:22 PM
worldpower's Avatar
ORIGINAL: drog321
actualy cars do sometime burn oil, some more then others and also oil grade can make a difference,
best hting to do is have an oil analysis or chang oil brands and see if it make a difference
Old Jan 2, 2008 | 05:48 AM
skanoski's Avatar
I had a similar deal.....oil was leaking from the bolts on the engine cover, dribbling down onto that flat metal pan (heat shield?) and then burning when it pooled up on the metal (leaving no oil under the car). I switched from synthetic back to dyno oil, and now it leaks and burns much less.
kelliott
May 31, 2022 05:26 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
