Engine Check Light + Washer Pump
Old Jan 5, 2009 | 05:40 AM
JagtechOhio's Avatar
Default RE: Engine Check Light + Washer Pump
Greetings,
Two separate faults, the check engine light being priority#1. You'll need to have the Diagnostic Trouble Codes identified with a scanner to narrow down the cause of the warning.
If our car is early enough, the map for the fuseboxes is on the cover for the one in the trunk. I don't recall which fuse is for the washer pump, it's probably in the right front forward fusebox.
More likely the washer pump has failed, it happens. Access to test for power is by removing right front wheelarch liner.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Xj812
Oct 26, 2015 05:04 AM
daro31
Aug 27, 2015 09:26 AM
divingmom
Aug 25, 2015 07:54 PM
