Engine got up to 249 degrees. Could this have caused Permante damage?
Old Sep 23, 2012 | 09:12 PM
burmaz's Avatar
Default Engine got up to 249 degrees. Could this have caused Permante damage?
My engine overheated today although I turned it off before the temp gauge pegged. Prior to the overheat, the torque converter kept locking and unlocking while driving on the freeway, and would randomly not shift up a few times when driving at city speeds (revs got up to about 2500rpm on light throttle). 'High Gearbox Temp' flashed for a half second and went away. The car then overheated. Immediately after I turned off the car, I checked the coolant temp with my code reader and it was 249 degrees. I estimate the car ran this temp for about 10 seconds. No hoses blew, but my coolant cap shot some coolant out. No steam. The cooling fans shorted out because of a wire that got cut in the fan blade which caused the overheat. I already replaced the water pump, hoses, and thermostat last year.
The car is a 2000 VDP with 110k miles.
Should I be concerned about long term reliability issues from this? At what engine temp does engine damage occur on these cars? Anything to worry about for the transmission?
Old Sep 24, 2012 | 04:58 AM
Sean B's Avatar
fix the fan wiring and say a prayer! you're gambling...
Old Sep 24, 2012 | 05:45 AM
If it's happened you'll find out soon enough. It's very unlikely to create a situation where something will subsequently fail as a result many months or 1000's of miles later.
Old Sep 24, 2012 | 06:44 AM
abonano's Avatar
+2 Good Luck! Finger's Crossed - (I think you'll be OK - but double check everything)
Old Sep 24, 2012 | 09:46 AM
Rlover's Avatar
If it ever happens again regardless of any car, do NOT shut it off, turn the heat on full blast and DRIVE, she will cool down, then shut it off.
Old Sep 24, 2012 | 09:57 AM
RJ237's Avatar
Rlover, I can't see that working if the water pump fails, thermostat sticks closed or coolant is leaking.
RJ___________________
97 XK8 86 K mi
Old Sep 25, 2012 | 09:20 AM
Rlover's Avatar
97 XK8 86 K mi
True good clarification., only works when fans fail...
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
OkieTim
Sep 2, 2015 12:48 PM
