Engine just dies
Old Dec 18, 2011 | 12:31 PM
jockellis's Avatar
Default Engine just dies
Sometimes we'll be slowing for the light at the GA 400, GA 369 intersection (which should be an overpass) and when I accelerate the car will just die. As for my wife, she doesn't even have to be slowing, just driving along and all of a sudden, she has no power. Put it in neutral or, if stopped, park and it fires right back up. Anyone have this?
Old Dec 18, 2011 | 01:11 PM
test point's Avatar
The '97 - '99 model years were subject to a throttle body recall / ECM reflash depending on VIN. Symptoms were engine shut down while driving and easy restart on the side of the road. Many got new TBs but the recall has now expired. Your solution is probably going to be a rebuilt TB.
Here is the Technical Service Bulletin on the subject.
File Type: pdf
Old Dec 18, 2011 | 02:38 PM
ant17's Avatar
Could also be an intermitant fuel pump problem.
Lots of things to test. Like fuel rail pressure among others.
Old Dec 18, 2011 | 03:15 PM
Gus's Avatar
Gus
Your problem has many causes fuel, throttle body and brake switch. Do you have any codes or do you get a failsafe or restricted performance? Was your cruise control on?
Old Dec 19, 2011 | 10:38 PM
orca99usa's Avatar
Also check to see if the throttle plate is dirty. That can cause slow speed stalling.
Old Mar 26, 2012 | 07:59 PM
wjgesq's Avatar
Default Throttle
Body, is the prime suspect.
dsnyder586
Dec 29, 2024 07:39 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
