engine shaking?
Old May 18, 2008 | 01:06 AM
JagtechOhio's Avatar
Default RE: engine shaking?
Greetings,
Don't get too concerned about worst case scenarios just yet. The first thing you should do is to locate a competent Jaguar technician in your area, and posting such a request here might prove to be effective.
The Engine Control Module in your car will have a fault code stored which will help to identify the cause of your missfire. The problem could be as simple as a failed spark plug or ignition coil. Your car does not have an EGR valve...it is also not one that is user-friendly in terms of home repairs by a novice. If you decide to attack the problem yourself, have the DTC codes read with a scanner and post them on here. There are others with more time andpatience than I who might be able to walk you through diagnostic and repairprocedures. Best wishes,
Andrew Bernstein
British Auto Care
Powell, Ohio
Old May 31, 2008 | 09:53 AM
jag_genius's Avatar
sounds like you need #2 ignition coil.. and i wud replace both knock sensors.. and then take it for a drive..
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
