Engine Swap
Old Sep 13, 2009 | 12:09 AM
Namor's Avatar
Default Engine Swap
I need to know what complications there are in swapping the motor from a 2000 XJ8 VP to a 1998 XJ8L.
It looks strait-forward to me. Swap the motor and the ECU and call it a day. Am I out of line? Will it be more difficult than this?
Essentially I can pick an 80K 1998 XJ8L with 80k miles that had the secondary tensioners go bad and therefor ruin the motor. Picking up that L-series would be a help because my 2000 VP has a ruined tranny and rear differential. I think if I swap the motor I would be a happy individual and have a fun project.
BTW the XJ8L is only $1000 dollars and is in excellent good super condition other than the motor. Thoughts?
Old Sep 13, 2009 | 01:03 AM
johnleavitt's Avatar
I would rebuild the second motor first....as long as you have it out, do a valve job and rering with a new set of bearings, tensioners, etc.. I have no idea if the swap is an easy one, but I would bet it would be as you describe.
Old Sep 13, 2009 | 02:02 AM
avos's Avatar
Easy swap, if the 1998 has a AJ27 (should be), then you can re-use all the hardware. But as I am not so familiar with the NA engines, I would re-use the cams/cam vvt gearing, oil pump and re-use all of your 98 electronics.
Old Sep 13, 2009 | 07:03 PM
wazari's Avatar
98 model year has an AJ26 motor.
Old Sep 13, 2009 | 11:27 PM
Namor's Avatar
Thanks for the help. I'm not going to go for it. The donor car i was going to buy was not accurately described. I do wonder about people an taking care of their cars. You should have seen the paint and interior. It was like an angry gorilla with a bucket of acid was allowed to have his way with the vehicle for about 10 minutes.
Oh well.
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
