EP-90 gear oil???
Old Nov 29, 2018 | 01:58 PM
OUScooby's Avatar
Default EP-90 gear oil???
I'm in the middle of installing the heads on my XJR and the workshop manual says to lubricate the journals and cam lobes with EP-90 oil. But I can't find ep-90 oil anywhere. A quick google seems 80w-90 gear oil is basically the same thing, is this OK to use instead?
Old Nov 29, 2018 | 02:25 PM
Carnival Kid's Avatar
EP-90 stands for extreme pressure 90, it has additives in the oil designed to protect against high pressure sliding contact, such as gears, and cam lobes. If you have some EP I would use it, but as the engine survives quite well on regular multigrade when it is running I would say that any lubricant would be fine, just make sure everything is soaked in oil. Alternately you can buy products like Lucas Assembly Oil which is designed for such a purpose.
Old Nov 29, 2018 | 02:36 PM
OUScooby's Avatar
Well I'd like to use the EP90 then if I can find it. Anyone have any idea there you can get some????
Old Nov 29, 2018 | 04:24 PM
Your shop manual was written a long time ago, and in the UK, and EP-90 as such probably isn't available now, at least in the US. EP rating has been replaced with "GL" rating, GL-4 and GL-5 gear oils, which you should be able to find at any local auto parts store.
Old Nov 29, 2018 | 04:32 PM
King Charles's Avatar
Yes EP90 was/is just the single viscosity version of 90 gear oil.
http://www.benquip.bz/view/product/41
http://motolube.org/products/69-ep90-gear-oil
Old Nov 29, 2018 | 04:42 PM
OUScooby's Avatar
EP90 Gear Oil - Motolube
I ended up paying a visit to the machine shop that rebuilt the heads and asking what they recommend using and where I might be able to find it. They hooked me up with a few small packages of Jesel Valvetrain oil. It's an EP oil, but its thicker (almost a grease) and higher weight than EP-90 and designed specifically for valvetrain assemble.
Old Nov 30, 2018 | 07:36 PM
Andmars's Avatar
Interesting. The key ingredient is zinc, often called for when breaking in aftermarket camshafts. You can buy oil additives for engine break in which are basically zinc based.
Old Nov 30, 2018 | 07:54 PM
Alfred Firmani's Avatar
EP-90 is used in classic motorcycle gearboxes. I use it for my Norton. Any classic motorcycle source should have it.
Old Nov 30, 2018 | 07:58 PM
Castrol Classic EP 90 gear oil 1 litre tin | SRM Classic Bikes
Old Nov 30, 2018 | 08:41 PM
OUScooby's Avatar
Yeah i found some places online selling, but still wouldnt know were to find it off the shelf
Old Nov 30, 2018 | 08:43 PM
Unless you have a classic bike place nearby, you will only find it online.
Old Dec 1, 2018 | 10:51 PM
OUScooby's Avatar
So this is what I ended up using. They were samples giving to the machinist at the shop that rebuilt the heads by one of their vendors and he was kind enough to pass them on to me. It was essentially the same stuff as the tube of EP oil he was already using which he said he gets from McMaster Carr, it was EP-120 oil or something like that. I don't know ow viscous ep-90 oil is but this stuff is more like a grease than and oil. Anyway it was explained to me that its the extreme pressure properties that you want more than the weight so as long as its at least a 90 going heaver should not matter. Besides the stuff I used is specifically for valvetrain assemble anyway.
Old Dec 2, 2018 | 02:59 AM
M. Stojanovic's Avatar
Originally Posted by OUScooby
So this is what I ended up using. ...it was EP-120 oil or something like that. Besides the stuff I used is specifically for valvetrain assemble anyway.
I think that staff is better than the plain EP-90 oil. What I used was EP-90 but I also mixed it with Liqui Moly MoS2 engine oil additive, just to have some extra protection against cam scuffing.
Terry H
Aug 6, 2013 03:02 AM
Disco stu55
Photography
80
Nov 12, 2012 12:59 AM
Moe-she-sa
Dec 21, 2011 08:52 PM
SkipM
Nov 25, 2011 02:16 PM
