Error codes
Old Aug 18, 2018 | 02:07 PM
xjfourty's Avatar
Default Error codes
Hello 1998 XJR here.
Right after inflating tires and car wash after 1 mile drive:
  • ABS failure
  • Traction control Failure
error code P1111 manufacturer control...
that seems so scary...
any ideas ?
thank you a lot
Old Aug 18, 2018 | 02:45 PM
Code P1111 is NOT an error - it is a status. You will ALWAYS see either P1000 or P1111:
P1000: on-board diagnostic tests have not been completed
P1111: all on-board diagnostic tests have been completed
Think about the car wash and water and wheel sensors .....
Old Aug 18, 2018 | 03:50 PM
RJ237's Avatar
And old plastic electrical connections in general. It should be alright when it dries.
Old Aug 18, 2018 | 07:45 PM
motorcarman's Avatar
Or C1095 or Front ABS link harness fault or??
C codes are NOT P codes!!
The engine module (P codes) doesn't really care about the Chassis (C codes) (except as a network info transfer) and will not normally log a C code in the ECM.
You will need a specific diagnostic tool to read the codes from other modules in the network. The ECM is not your problem, the ABS module is your concern.
bob
File Type: pdf
Old Aug 20, 2018 | 05:33 PM
xjfourty's Avatar
thank you.
yes the problem disappeared after 10 minutes driving the car...
Old Aug 20, 2018 | 08:22 PM
The fault might have 'disappeared' but the DTC is still logged in the module!!
What was the DTC??
bob
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
Apr 9, 2007 09:18 PM
