Evap purge valve updated part number
Old May 17, 2022 | 06:36 PM
Quadcammer's Avatar
Default Evap purge valve updated part number
Hi,
I'm working on a 99 xjr I just purchased. Car is in good shape, but fighting some evap system codes, primarily the p0447 (which is the canister close valve).
Being a 99, I have the LNC1515AA valve. This appears to have been discontinued by the fine folks at jaguar.
So, is there some superceded part number, or do I just have to try to get lucky with a used part?
The lack of parts availability is a touch scary.
Thanks all.
Old May 17, 2022 | 06:38 PM
Quadcammer's Avatar
sorry for the confusion, but I also tested the purge valve and it did not seemed to be operating properly. Hence the question.
Old May 19, 2022 | 09:19 AM
Quadcammer's Avatar
To close this out, it seems like we are outta luck. As a result, I found the best condition used LNC1515AA I could find and will install that.
Scary though that parts availability is likely a problem for the earlier cars.
Old May 19, 2022 | 03:09 PM
RandyS's Avatar
Default alternative parts that may work
Emission Components for 2003 Jaguar Vanden Plas | Suburban Auto Parts
I suspect your purge valve may be quite similar, if not identical.
Take a quick look and see.
dsd
Apr 10, 2017 04:20 PM
Spikepaga
Jan 31, 2014 03:53 PM
x300man
Aug 20, 2013 10:21 PM
Oldengineer
Apr 11, 2009 03:48 PM
