factory jaguar block heater
Old Feb 14, 2014 | 12:55 PM
jaguarcraver's Avatar
Default factory jaguar block heater
Does Jaguar make an engine block heater? If so, would anyone know the part number? Thank you very much, Louis
Old Feb 14, 2014 | 03:17 PM
plums's Avatar
Yes, and you will find it is very expensive.
On the aftermarket, there are only a few cars that have the same thread size and it is hard to determine if the element will fit.
The aftermarket does not list a block heater for the X308 specifically. Not even the supplier of the OEM part. Must have been an exclusive deal. The OEM installation includes a foil sheathed power cable running to the grille terminating in a flat pack connector and a pigtail with a mating flat pack connector and a household plug.
You might look at coolant heaters that install into a radiator or heater hose as an option.
You would need to ensure that the particular coolant heater is compatible with the cooling system layout as it is a bypass layout.
Old Feb 14, 2014 | 04:17 PM
vincent661983's Avatar
my question is why block heater?
Old Feb 14, 2014 | 04:58 PM
Thanks plums. I kinda had a suspicion it would be pricey. I will look again on JPEC to see if it is listed. I will probably pursue a coolant heater as you advised.
Old Feb 14, 2014 | 06:31 PM
luc's Avatar
luc
I put one on my XJR. price was not too bad but that was years ago. Now part JLM20724 retail for almost $150.
The kit has the heater and 2 electrical harness
Old Feb 14, 2014 | 09:46 PM
jimlombardi's Avatar
Ebay has an aftermarket one for XJ V8 4.0L:
Jaguar Block Heater Kit Engine Heater Kit Jag Jaguar 4 0L 4 2L V8 Engines | eBay
Also on this website:
http://autocoolingsolutions.com/prod....2L-V8-Engines
Jim Lombardi
Jandreu
Aug 23, 2019 11:37 AM
Xj812
Oct 26, 2015 05:04 AM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
bigw909
Aug 30, 2015 09:29 AM
SatanClaus
Aug 29, 2015 09:15 AM
