Failsafe engine mode, Please help!
Old Jul 31, 2011 | 11:47 PM
QuadManiac's Avatar
If I recall, there are two switches - one for brake lights, one for Cruise interrupt (called the Brake Cancel Switch)... have you checked or replaced both?
If I also recall correctly, if they don't report agreement(both open or both closed at same time) to the processor when the cruise is turned on, failsafe mode gets tripped.
Old Aug 4, 2011 | 09:26 AM
johnleavitt's Avatar
I have replaced the white brake switch, but am unfamiliar with the other switch. do you know what it looks like, or where it is, or what the part number would be? As it turns out, sometimes the problem does not start for a few seconds after the cruise control switch is turned on.
Old Aug 5, 2011 | 09:32 AM
mzs_biteme's Avatar
@johnleavitt,
If you replaced brake switch, you also replaced the Cruise Interrupt switch QM is talking about. It's part of the brake switch. There are two micro-switches in the brake switch housing...
Old Aug 8, 2011 | 05:56 PM
xjrdaddy's Avatar
my 99 xjr did the same thing it end up being a broken t fitting on the vacuum line. mine was on the cruise control under the plastic on the driver side i had no codes so look for that stuff. it would have to be little or u would get a code hope it helps
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
