Failsafe Mode - No Codes
Old Sep 14, 2010 | 09:09 PM
TN8Shooter's Avatar
Default Failsafe Mode - No Codes
I was driving home today and stopped at a stop sign. My car stumbled briefly and the Red light came on with a failsafe mode message. I pulled over to the side and shut the car off. I quickly re-started and the message was gone and the car was back to normal. When I got home I connected my scanner, but there were no codes.
Any thoughts?
Old Sep 16, 2010 | 10:56 AM
kenncl's Avatar
Failsafe can be triggered by a multitude of things. Mine did not show codes either. I cleaned throttle body and MAP, and the failsafe stopped happening.
Good Luck
Old Sep 16, 2010 | 11:19 AM
Gus's Avatar
Gus
Take a look at this information. http://www.gusglikas.com/AutoRepTB.htm Now you say you did not get a code on this and I found recently that the plug problem does not always set a code. If you are not sure this is the problem pull the TB plug and clean it and see if it reappears.
Old Sep 16, 2010 | 10:54 PM
TN8Shooter's Avatar
I went ahead today and replaced the secondary tensioners (125K and never changed the originals). I found that 5 of the 8 spark plugs were caked with oil. The load breather tube needed to be cleaned, and I had a crack in the passenger side breather tube.
New tensioners, valve cover gaskets, spark plug gaskets and plugs all went in today. Car is running like a beast now!!!
Old Sep 17, 2010 | 03:39 AM
Cadillac's Avatar
I am glad you fixed your problems
Enjoy your beast
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
Jagged-X
Sep 24, 2015 05:08 PM
John Fox
Sep 19, 2015 07:56 PM
tsimms7
Sep 15, 2015 12:43 PM
