Failure to Start Engine
Old Nov 18, 2013 | 04:35 AM
Alhajivinco's Avatar
Default Failure to Start Engine
For sometime now, my 1998 Jaguar XJ8 has been acting up. After about 3-4 days of not driving the car, when you turn the ignition on, it is almost impossible to start it because it appears the battery has run down. The car is usually started with a jump cable. I bought a brand new 90amps battery a couple of weeks ago and it all seemed fine until a few days ago when the car failed to start. On the first day, I tapped the battery heads with a spanner and the car was able to start. Now the battery appears to have gone dead. It did not even respond to a jump cable. Does anyone know what could be wrong?
Old Nov 18, 2013 | 05:02 AM
Alhajivinco,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X308 forum. Members here with the same model will be able to help.
The Jaguar Forums Advice / Feedback & Suggestion Center is for posts about the forum and not for tech questions.
Old Nov 18, 2013 | 05:11 AM
As you have fitted a new battery and it will not jump start, check the cable connections:
1. negative ground (circled in red)
2. positive junction box (arrowed in red)
The positive connection is a known issue for loosening or the cable terminal deteriorating.
Old Nov 19, 2013 | 05:18 AM
Default Failure to start engine
Thanks GGG, I will check out the box and cables connect to the battery as you suggest.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
tberg
Sep 7, 2015 07:32 AM
Harry Dredge
Sep 3, 2015 03:04 AM
TC Johnson
Sep 2, 2015 09:30 AM
