Fans not working
Old May 20, 2009 | 01:26 PM
griffplus's Avatar
My car did that but i noticed that the radiator had moved out of position at the bottom and the lower fan could not spin so it tripped the fuses. The interesting thing about this car is that the fans only come on when needed and often it isn't check your fuses to make sure they are good. It is fuse Number 14 and the fuse is a 30 AMP so make sure u have a few just in case there is an issue, like a short.
Old May 20, 2009 | 06:03 PM
jag_genius's Avatar
the relay is a common failure.. two relays in one.. left side of front bumper.. 3-4 inches tall by 1 inch ..big wires going into it about $ 65.00 or can be the wiring to the relay
Forcedair1
Sep 8, 2025 01:57 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jehart49
Sep 12, 2015 05:36 PM
philwarner
Sep 5, 2015 10:05 AM
