Fault message
Old May 20, 2017 | 07:05 PM
remccallum's Avatar
Default Fault message
Had electrical message appear on my dash 2000 xj8
Old May 20, 2017 | 08:10 PM
harvest14's Avatar
Can you provide a little more detail? What did the message say? Were there any other symptoms of an issue?
Old May 21, 2017 | 09:44 AM
remccallum's Avatar
I was on the highway when the message came on long enough for me to read then went out. It did not affect the car,just the msg.
Old May 21, 2017 | 09:59 AM
harvest14's Avatar
Were you accelerating aggressively? If your rear wheels (drive wheels) slip any during acceleration you'll get a message in the display very briefly that lets you know the traction control system is engaging. It's not a bad thing, if that's what it was.
I know on many cars if you get an intermittent misfire then it only gives an error message while it's actually misfiring. Not sure if the X308 is the same. It seems a misfire would also trigger a lingering code though. Reading the codes is really your next step. See if anything is pending...
Old May 21, 2017 | 04:35 PM
remccallum's Avatar
I was just cruising And checked no codes I think maybe it was just random but had not seen electrical fault message before
Mike_VDP
Apr 30, 2017 03:16 PM
Mike_VDP
Apr 29, 2017 07:25 AM
Pure444
Jul 19, 2014 12:09 PM
Peter Garrod
General Tech Help
Jan 17, 2014 11:29 PM
heybeck
Jul 16, 2012 12:24 PM
