Faulty Brake Pedal Switch?
Old Feb 9, 2016 | 07:09 PM
roberthornsey's Avatar
Default Faulty Brake Pedal Switch?
Does Jaguar publish the specs for bench testing the subject switch P/N LNB6420BB? I've been experiencing the Failsafe Engine Mode warning (DTC P1571) with concurrent loss of cruise control. The fault doesn't trip if I drive with the cruise control disabled. I've had the switch out and appear to get a much higher resistance on the center two pins than the outer two when the two small push button switches are depressed. Suggestions?
Old Feb 9, 2016 | 07:21 PM
RJ237's Avatar
I don't think there should be significant resistance. It sounds like time to replace the micro switches or the whole thing. There was a thread on this or the XK8 forum yesterday, I think, in which one of the members described the micro switches.
Old Feb 9, 2016 | 07:34 PM
sparkenzap's Avatar
These switches are SWITCHES! I guess you found the problem.
Old Feb 11, 2016 | 07:00 AM
yeldogt's Avatar
You will find a TSB on the switch.
I would replace it -- they are not expensive.
Old Feb 11, 2016 | 03:18 PM
TXE36's Avatar
IIRC, and it has been awhile, there are two identical microswitches in that assembly. In my case, one of them was "lazy" when opening and closing. Using a soldering iron, I swapped them and the problem went away.
I think one is used for the brake lights and the other goes to the cruise. It should be in the schematic documentation.
-Mike
Old Feb 11, 2016 | 03:43 PM
Just ordered a replacement switch assembly. Hopefully that corrects the problem? Or at least I'll have something to compare resistances. As an aside I've noticed, since I turned off the cruise control, my passenger side mirror no longer drives into the lower stop whenever I used the key fob to unlock the doors. Maybe the new switch will fix that too!
Old Feb 11, 2016 | 05:10 PM
sparkenzap's Avatar
Well, you did not say how much higher resistance one switch read from the other, but if either is reading more than 4 to 8 ohms, you have a bad switch.
Old Feb 11, 2016 | 05:41 PM
andrew lowe's Avatar
The 2 microswitches work opposite to each other.
The one for the brake lights, makes a circuit when the pedal is pressed, the one for the cruise, breaks the circuit when the pedal is pressed.
caldercay
Sep 17, 2022 07:59 PM
peterg19
Jan 21, 2016 06:56 AM
roberthornsey
Jan 19, 2016 07:36 PM
JagGirl1954
XE ( X760 )
Jan 12, 2016 09:18 PM
Tirefriar
XE ( X760 )
Jan 12, 2016 09:05 AM
